メインコンテンツにスキップ
The Samsung Galaxy Tabs are Samsung's flagship tablets that compete with iPads.
20回答 すべてを表示
Why Isn't my tablet turning on?
Okay, so this morning I dropped my tablet, while getting out of my car and it fell on the ground and cracked slightly. I could still use it, however. The touch ability worked and everything worked as normal, just that it had a crack at the corner and across it. So then later this evening it suddenly turned off?? Like it wont even respond when I put it for charge or touch the home screen button??
Also, I don't know if this is going to be helpful, but a few minutes before the tablet turned off I had put it on top of the laundry basket. The clothes weren't really that wet, but I don't know if somehow the screen is extremely sensitive to water and it seeped through the cracks and damaged the tablet further or something??
Please respond!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
i think i would like you to charge your tablet for 30 min and make sure you see the charge is coming to tablet .
than press the power key and hold for like 40-50 sec and wait see if this turn on . t think charger socket may be broken . try opening the tablet using ifixit tools and see if you check the charger socket .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dangerousdream29 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 80
