メインコンテンツにスキップ
京セラ製のAndroid スマートフォンの修理ガイドです。
79の回答 すべてを表示
wont charge usb port broke
Kyocera android phone wont charge the usb port is missing the teeth
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
1 件の回答
選択されたソリューション
Hi,
As you do not state the model number of your Kyocera phone, this answer will be of a general nature regarding Kyocera phones.
The USB charge port on most Kyocera phones is surface mounted onto the systemboard. From the description that you have given as yours is missing its' connectors it will have to be replaced.
To do this you will need to:
Have some appropriate tools to be able to open up the phone so as to gain access to the systemboard.
Have surface mount soldering tools and skills.
Need to source the exact USB connector type, as to configuration and tethering to replace your faulty port.
If all this sound too daunting I suggest that you contact 2 or 3 reputable, professional mobile phone repair services and ask for a quote to repair your phone. I say 2 or 3 as this will give you a better idea of the cost of the repair if all the quotes are reasonably close. Also ask how long a guarantee they give on their repairs. Most reputable repairers give at least a 30 day guarantee.
この回答は役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Nici Edwards さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 410
