won't start runs & dies replaced coil, coil wire, no spark
1993 toyota tacoma 4x4 won't start & sometimes quits when running. won't start now
Have you tested for spark at the coil? At the plugs? If not test first.
Sounds like your maf sensor or engine coolant temp sensor or something like that isnt getting good connection. If the maf sensor, it will crank up and die. Same with ect sensor. Knock sensor, it will run like crap and die when trying to accelerate.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 93
ron jacobson what engine does it have and what have you checked?
oldturkey03 さんによる
