Last 3 baseboard heaters on loop are not getting hot enough
I have a hydronic baseboard heat system which 1 zone serves multiple baseboard radiators heaters and it is a long loop.
The last 3 heaters are not getting hot enough.
I'm a plumber by trade and I bled the system.
I'm wondering if there is any solution to get the last 3 radiators on the loop as hot as the first few radiators without having to repipe for a separate zone.
Thank you
この質問は役に立ちましたか?
12 件のコメント
Hi, Perhaps a naive question, but is the pump moving the water through the system fast enough or is it slow and the water 'cools' before it reaches the last 3 radiators? is there a flow control valve that may be clogged etc?
jayeff さんによる
It's definitely moving water, otherwise on of the radiators would get hot.
As well as I can hear/feel the circulator working.
But I'm not sure if I might need a stronger circulator, don't know how to do the math on it.
Abraham Yaris さんによる
Hi, Is the temp 'in' on the 4th last radiator in the run a lot different to the temp 'out' when the pipes are felt by hand? and is the temp 'in' on the 3rd last radiator nearly the same as the temp 'out' of the 4th last radiator? just wondering if the radiator might be clogged slowing flow.
jayeff さんによる
4th last radiator is not a big difference on the in & out,
And the 3rd last in is also not a big difference of the 4th last out.
Abraham Yaris さんによる
Hi, This link has tables which give flow rates and temps and element length for a loop. It might be of some help to you.
https://heatinghelp.com/systems-help-cen...
jayeff さんによる
7件以上のコメントを表示
