メインコンテンツにスキップ
2.0GHz, 2.3GHzもしくは2.6GHzクアッドコアIntel Core i7プロセッサ (Turbo Boost 最大3.8GHz) 6MB共有L3 キャッシュ付き。
580回答 すべてを表示
Bought a used MacBook Pro, keyboard backlight not working
So I got a good deal on a max spec late 2013 MBP, the only problem is that the keyboard backlight doesn't turn on, the rest of the machine works fine. Is this something I'll have to replace? If so what part do I need?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Here is a link to Amazon with the keyboard/backlight.
https://www.amazon.com/gp/product/B01HRO...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
Remove the bottom cover, disconnect the battery, disconnect and check the backlight connector (to the right of the left fan, at the top of the board). Since this is at the edge of the board, it is very easy for it to get liquid damaged and damage the connector on the board. If there is any corrosion, clean it with isopropyl. If not, it could be an issue with the part (very unlikely for it to not work at all, unless opened and damaged before) or it could be an issue with the backlight IC for the keyboard backlight. If the connector is burnt, you will have to solder a new one.
Before all this, try an SMC and PRAM reset. Also, put your hand over the camera and try increasing the backlight using the keyboard.
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
The connector looks fine but it still doesn't work, I tried resetting the SMC and PRAM, that didn't work either.
さんによる
Does the keyboard backlight connector look ok? If not, try a test backlight. When you increase the keyboard backlight using the keyboard, does it let you increase it or show a prohibited symbol? If latter, cover the front camera and try this (too much light), if it increases, will be the backlight or an issue with the keyboard backlight voltage on the board (at which point, I would recommend taking it to someone who can diagnose this)
さんによる
It shows that it's increasing and covering the camera does nothing. The connector looked fine.
さんによる
Will be an issue with the board if this is the case and you have tried a test backlight. Will either be the connector or the backlight boost for the keyboard
さんによる
Can I order a new backlight?
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
ShadowTech さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,790
