メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
The Toshiba Chromebook 2 laptop was released in 2014, and the model number is CB35-B3340. This Toshiba Chromebook is silver with a 13.3" high resolution screen.
25回答 すべてを表示
Are replacement keyboard/top cases compatible across different models?
I have a Toshiba Chromebook 2 2015 with a Canadian English keyboard, and would like to replace it with a USA keyboard (the enter key bothers me as I am used to the enter key of the USA version.)
My question is- do I have to buy a keyboard/topcase specific to the Toshiba Chromebook 2 2015, or can I use one from the previous Toshiba Chromebook 2 model?
All the Toshiba Chromebook 2 models look physically identical, so I imagine this would work. I understand I would be losing the backlit keyboard feature if I did so, as I would just like the cheapest replacement possible.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi!
You can try???, just keep in mind not to damage the new keynoard if you need return it. Just make sure that the connections, size and shape are the same before you buy it...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
madmaxmedia さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 91
