メインコンテンツにスキップ
家庭用から車のオーディオシステム、計算機など幅広いエレクトロニクスギアの修理ガイド
10480の回答 すべて表示
Is this capacitor bulged?
Hello,
Does the reddish top capacitor looked bulged to you?
Thanks.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
@paragon_ no they are not. The caps look good. If it would be bulged, the seams would have opened up (even just partially).
による
Hi, Why do you suspect that a capacitor may be faulty? What item of equipment are you having problems with? As @refectio says it is better to remove the capacitor and test it to definitely prove whether it is faulty or not. using an LCR & ESR meter
による
Thanks oldturkey03, that was helpful.
Jayeff, I am having problem with a washing machine board, but just did not want to remove anything at first because the whole thing is covered with silicon. Thank you
による
コメントを追加
iPhone X用修理キット
Warranty up? No worries, we’ve got the fix.
ショップを見る
iPhone X用修理キット
ショップを見る
2回答
選択されたソリューション
When in doubt switch it out . To test it is to pull it so just switch it out . the capacitor doesnt look like its broken a seam but it does look like its leaking . Use a magnifying glass and check for a break in the seam close to the center where the red is on the seam as for bulging you need to provide a side view for that
この回答は役に立ちましたか?
スコア 4
コメント:
Thanks for your answer Jimfixer. The red at the top seems to be some sort of paint. I was just wondering because the seam gap looks a a bit too deep, so I asked for opinions before anything since the whole board is covered by silicon.
による
コメントを追加
The red top could be ink or something else. Generally, leaking electrolyte will not leave a red residue. If you want to be certain, remove the capacitor and test it with a multimeter that has capacitance or even better with an LCR meter.
A side view would be better but the capacitor does not look bulged.
この回答は役に立ちましたか?
スコア 3
コメント:
yea...a side view would help a lot. I don't see any leakage but I can't tell if any are bulging. Like Minho said, its best to throw a meter on them just to be sure.
による
Thanks for your answer Minho. I just did not want to remove it at first.
による
コメントを追加
回答を追加する
Paragon さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 141
