メインコンテンツにスキップ
The eMac was an all-in-one G4-based Mac designed for the education market and released in April 2002. It was the last Mac to use a CRT display and was sold at a low price to schools and other institutions.
eMac won't boot either
Emac will not boot after last software update. Will not boot from hard drive or disk. Three things happen. First, I get a kernal panic and freeze after a few seconds, or the computer shuts down. or the spining indicator goes on indefinitely. On rare occasions, I get the symbol for OS not found. I have reset the PRAM and I get both bongs. Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
Thanks for suggestions, but nothing worked to boot the machine. I do not know if we are facing a bad hard disk or mother board. If it was a hard disk, I assume I should have been able to boot from the install disk. So I fear it's a mother board. Until next time....Adios
さんによる
コメントを追加
2件の回答
ベストアンサー
Boot from your system installation disk by inserting the disk and starting up holding down the "C" key. Go to the second screen pull down menu to Utilities -> Disk utility and repir the hard drive till it runs clear. Then try restarting.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
agreed +
さんによる
コメントを追加
Sounds like one of the updates failed. If you still have the install disks, you can reinstall the operating system and select the option to save all of the old files in a folder called "Previous System" If you want to keep them, and have inportant info that you want to keep. Short of that, there is no way to really fix this.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
professor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,260
