From my experience on previous repairs and also from what I have learned from Chris Long videos, If *#06# does not display the IMEI, it is Baseband. First, check well for short on caps around baseband, if not any...run jumpers on U1 and V1...
Just reflowing the IC will not be enough for this type of repair. As Chris Long explains in his Iphone 6 Plus "No Service" repair, you will need to remove shield, remove Baseband, Reball, Clean pads, and run 2 jumpers to the U1 and the V1 pads. (Much like the M1 Meson U2402 jumper).
Although you can also run short jumpers (Which do not last as long), it is recommended to remove the Sim slot and run the "Long jumpers".
Go watch a video from Chris (Starts at about 3:55:00 that gives a full explanation and the process for this repair, as well as other things that can cause this issue.
9 件のコメント
Ardian a mundesh me um kontaktu ne email xhani_17@icloud.com
Urim Demiri さんによる
My Iphone 5 I type *#06# have imei but no service why?
Danial さんによる
Hey I have also the same problem. How you found the solution. How you heat the imei ic?
Ammar Tarar さんによる
Can I remove my second hand iPhone 5s from icloud permanently lock? If possible please helpe me
Susan Goerge さんによる
Hello everyone, I don’t know who will see this but I need help on my iPhone 6 that won’t read my sim. I have gotten a chip, changed my sim slot, and my Imei is currently unblocked but won’t show when I try the *#06# . Please I need urgent help for my sim to work.
Adaeze eze さんによる
4件以上のコメントを表示
