Touch ID fails, double tap works
Hi everyone!
After I replaced the screen (screen only) on my iPhone 6S, the Touch ID fails - even though the double tap for one-handed mode works.
I already transfered the small conductive plate beneath the connector (like described in Touch ID not working after screen replacement?) and took everything apart and reassemled it plus did a factory reset and disconnected the battery.
I was very gently while transferring the home button to the new screen - there is absolutely no optical damage.
What would be the next, you would try?
Could it be a problem, that I used the phone for testing purposes with another display and home button for some time?
Thanks for your help in advance.
この質問は役に立ちましたか?
3 件のコメント
The chances are the home button extension cable may be faulty on the replacement iPhone 6s screen, every screen comes with it assembled together.
Ben さんによる
Well, that's worth a try! I'll check it with the old broken display tonight. Thanks :)
Sebastian さんによる
Didn't work with another screen. Either the Touch ID IC is broken or ... :-(
Sebastian さんによる
