What is the proper way to disassemble the LCD
Hi, I want to replace the broken digitizer LCD on my laptop without breaking it, is there a step-by-step link on doing this (it's a touchscreen) without ruining my laptop even more?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@luluconley , Louise, Screen disassembly video below of Toshiba P55, may not be your exact model, but hopefully will help in the replacement of your screen. Good luck.
このアンサーは役に立ちましたか?
I'm not familiar with that particular laptop but most follow the same principles. Remove any screws around the bezel, usually under rubber screw caps, then prize off the bezel with a spudger or a thin but blunt knife. A few more screws must then be removed to free the LCD. Gently angle it forward in order to disconnect the cables. It's easier if you remove the screen from the laptop base, but that's a fair bit more work.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 65
