Laptop shut down, won't turn on anymore.
Month ago while on my computer, it's black out.
Shut itself off, and i have not been able too power back on.
Can i refurbish this unit?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Does the battery hold a charge ? Did you get a BSOD ? Did it give an error message when it shut down ? do you get any responce from the computer when you try to start it like post beeps or fan noise or hard drive noise . do you get any leds lite?
Here are some things to try First do a static discharge ,remove the battery unpug the power cord then hold the power button down for 60 seconds then plug it in and reinstall the battery and reboot . If this gives no Joy then try connecting to an external monitor . if this doesnt help try removing one dimm of memory at a time and booting to see if theres issue with the memory. If theres only one bar then find another stick of memory to see if that works . If one dimm of memory fails then the laptop will not boot. Try these and get back to use with your results so we can further diagnose your laptop
このアンサーは役に立ちましたか?
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 5,670
