Does anyone have the schematic for Altec Lansing acs33?
The sub stopped working. All else works normally. The woofer checks ok. Would like to troubleshoot amp.
Sometimes it could be due to bad IC chips, transistors, or failed capacitors, etc.
If you have a multimeter, it would be a good start.
このアンサーは役に立ちましたか?
I was wondering if I can wire my Acs 33 sub to work with None Ace 33 speakers or without out. What is the audio in pins on the 6 pin din?
Josh my altec lansing vs5121 was 120v however the audio board used 18vdc! So now it's running off a ryobi battery! I added a mp3 blutooth card reader! It's awesome. I can get a acs33 for 6$ used. Would you happen to know the operating voltage of the board in that unit?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,012
1件のコメント
did you get any ACS33 schematics?
stanley Siu さんによる
