メインコンテンツにスキップ
Appleは2880×1800ピクセル標準解像度でRetinaディスプレイを装備した新しいデバイスを発売しました。
3599回答 すべてを表示
Polish the trackpad due to uneven patch
Hi folks!
Today I received back my MacBook Pro 15" from maintenance service due to water damage. The technicians replaced the upper case including the keyboard, battery and trackpad. The trackpad may be a refurbished item because there is a little uneven path on it .
I won't bring it to maintenance again because I have to wait minimum two weeks again until themy 'may' decide to replace or not... and I expect they won't.
Is there any possibility to polish the trackpad? It is no deep scratch and you can't even see it. You can just feel it. It feels like it is some dirt on it of dirty cocolate-fingers.
It would be very nice if you were able to help me.
Thank you, have a nice Sunday and kind regard from Germany
Flo
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
If you have isopropyl alcohol, try rubbing down the trackpad and see if that cleans any uneven surfaces. If not, you can purchase a cheap vinyl skin to not only cover the trackpad, but to also give it a nice custom look. I would not recommend anything like sandpaper or any manual polishing that can give the surface an even more uneven feeling. Dbrand makes very high quality skins that you can check out here for your touchpad.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
floriandanker さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 1,076
