メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Do I have to re-put the adhesive strip for the battery?
I recently disassembled an iPhone 5c to replace the battery. It didn't have adhesive strips but instead it was simply glued, so I just took it off by force. The phone is working now, and the battery is in place.
My friend has 3 iPhones: 5, 5S ,5c. However, I am afraid that I'll need to also buy adhesive strips for the battery. Is this obligatory? Can I just put the battery and connect it? And was it bad that when i put a battery in the iPhone 5c I didn't glue it back?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
ベストアンサー
You should be using some sort of adhesive so the battery doesn't move around while it's installed in the phone.
Because if there is little to no adhesive you risk having the volume / power button ribbon / flex cables being cut from all the friction caused by the battery moving around. There is even a chance for the battery ribbon cable to be cut from this too.
Additionally if these phones came from clients or customers the chances are you will see them come back and complain about the battery moving because they can hear and feel the battery moving around.
You have a few options on what kind of adhesive you want to use.
The cheap quality one is just black double sided tape from eBay, next up is red tape (transparent adhesive) which you can also buy from eBay.
The best quality ones are the tesa tapes or 2x adhesive battery strips.
That's why I always come prepared with a decent amount of adhesive for battery or screen replacements without frame pre installed.
Edit: If you were asking about reusing old adhesive, it's highly recommended that you do not as they weaken a lot after being used once.
このアンサーは役に立ちましたか?
スコア 14
4 件のコメント:
Thanks. By the way, I replaced my iPhone5c battery. It didn't have an adhesive strip but was glued. I just re-put the battery. It this also bad?
さんによる
And can I just use superglue?
さんによる
dont use glue. use some kind of dubble adhesive tape.
さんによる
Superglue is a really bad idea. The next time you need to remove the battery it's going to be really hard and leave residue / difficult to remove.
Using hot-glue or b7000 glue is also not a good idea to use as adhesive for batteries.
さんによる
コメントを追加
is one adhesive strip enough? i went to a repair shop and have my battery phone fixed, i bought battery online from a legit shop and it came with two strips, but he cut it, put one to my battery and keep one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
AbAppletic さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 55
今までの合計 23,241
