メインコンテンツにスキップ
AmazonのBluetoothスマートスピーカー。2014年11月6日に発表されました。AmazonEcho SK705DIは、音楽再生、ニュースの閲覧、リストの作成、質問への回答など、さまざまなタスクを管理できる音声起動のクラウドベースのアシスタントを備えています。
42回答 すべてを表示
dropped my echo and now won't work
I dropped my Amazon Echo, the top fell out. I've put back together but can't get it to work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
1件のコメント
please help us to fix this problem.
we need a answer
さんによる
コメントを追加
2件の回答
最も参考になった回答
I had the same thing happen to me. The larger black top piece (containing the boards) has and input for a half inch long data cable. The data (ribbon) cable is on the piece below. Make sure to insert the data cable into the slot. It's important to close the flap on the slot for the cable to work. Be patient and you can do it. My 10 year old son was persistent and did it on the 3rd try. Good luck!
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
This fix works perfectly. Getting the data tape into the connector in the device required setting the little lock on top and that was a little fussy. Persistence paid off and the device is now working again. Thank you
さんによる
Happy to find this article, just what I needed, echo now works. The #1 key importance to this article, “close the flap on the slot for the cable to work”. Nearly 5 year old article but still relevant and saved my echo, Alexa is once again alive on the device, Thank You gregmerig
さんによる
コメントを追加
A small part of the light ring got stuck inside the speaker and now it's hard to change the volume. I can't take the part out to make it work smoothly again and I don't know what to do.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Same with me please help
さんによる
Had a similar problem recently.
I know it's been a while. We got one of these, new in the box at a yard sale for $35. It worked great until it took a spill from the top of a tall cabinet and landed head first on a hardwood floor.
Didn't work at all at first, but when I examined it carefully, I noticed the outer edge of the very top had been dented in, trapping the volume ring and deforming art of it to be above and some below the normal position.
I took a narrow flat blade (not sharp), instead it between the outside (the dented parts) and the inner ring and twisted back closer to but not entirely (the plastic would break if bent too far) and this had two effects. That is, after pushing the light ring back into place as much as allowed, the volume ring was now only slightly stiff - it's back on top of the cabinet - and it otherwise works perfectly.
Not sure I would pay more for one of these. The speaker quality is nice and fills a small room easily, but 90+% of the time, All she does is tell us the weather
さんによる
コメントを追加
回答を追加する
Julie Lane さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 17
過去 30 日: 74
今までの合計 9,756
