メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
モデル番号 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7プロセッサ
190の回答 すべてを表示
Won't boot afther upgrade to macOS Sierra
Hello I have a problem with my Imac 21,5" A1418 EMC 2544
I have upgraded From El Capitain to macOS Sierra.
After second restart it went i a boot loop with grey screen and boot chime over and over again.
I have disconnected my LCD and connected a external screen same thing .
When i boot up without internal or external screen connected no boot loop only 1 chime and then it runs high speed fan.
My question is how do i reset my NVRAM without screens and EFI password set ( I know the password set it my self ) .
Or can some one tel me what i can do about this or what part or parts i have to re-please so i have a working screen again .
With Regards
The Judge
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
2件の回答
選択されたソリューション
Try to press and hold Command-Option-P-R on bootup until you see or hear something new. Also, do you have another Mac that is new enough to download macOS Sierra from the App Store? If so, you can use target disk mode to install macOS onto the iMac via another Mac.
この回答は役に立ちましたか?
スコア 1
コメント:
Oke thnx for you answer.
I will try the target disk mode.
That is the only thing i didn't try jet .
The Judge
さんによる
Target Mode did the Job
I did have to reinstall OS X but that's oke
Thanks for the tip
さんによる
@thejudge Glad to hear that :) No problem!
さんによる
コメントを追加
最も参考になった回答
Your system maybe just fine!
Apple requires a full restart during the upgrade process a few times as the there is a firmware update as well as an OS update (I've had systems do four restarts to apply everything).
The other problem I've seen is a HD which has problems go into a tailspin of restarts as the firmware update is not able to complete. The only way to overcome this is to boot up under an external drive or use a second Mac system to fix if possible your drive using Disk Utility by putting your system in Target Mode. Otherwise you may need a new drive.
この回答は役に立ちましたか?
スコア 4
コメント:
The Judge
さんによる
Thanks for the tip
さんによる
コメントを追加
回答を追加する
The Judge さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 840
