メインコンテンツにスキップ
The Nikon 1 AW 1 is a waterproof camera manufactured in 2013. This camera is Wi-Fi capable and records in 1080p with a 14.2 MP lens.
Why doesn't it connect to wifi anymore?
I was using my Nikon 1 AW 1 the other day and I had no problems connecting it my home wifi. However, today I go to use my camera and now it won't connect. Is there anyway I can fix that or do I need to replace the camera completely?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Great question! Firstly, make sure you turn the camera on and off to see if that helps. If not, make sure the settings are set to allow wifi connectivity. If neither option helps, then you can certainly repair that without having to replace the whole camera, though it will take a little work. If you replace the motherboard then the wifi components (drivers/hardware) will be replaced with it. You'll only need to buy another motherboard for the Nikon 1 AW 1. Here is a detailed guide on how to do it yourself!
Nikon 1 AW 1 Motherboard Replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joshua Bohorquez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 249
