Why won't my battery charge?
My battery doesn't seem to be charging. I think it is plugged into the charger properly, what else could I do?
If your charging cable is securely plugged into your device and it is still not charging, the USB port may be faulty. Test your computer’s USB port by inserting a different device into the port and checking it if is functioning. If the port is faulty, plug your charger into a different port or a different computer.
このアンサーは役に立ちましたか?
I don't know . Someone tell me what to do .
このアンサーは役に立ちましたか?
I have found an easiest way to charge fitbit charge 2.. check it out..
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 1,488
