メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Get the digitizer assemply with or without the home button et.al.?
I will rplace the digitizer/screen on an iP5 and an iP6. (have done this for other phones)
Wondering if the extra $$ for the kit with the button, earpiece etc is worth it, there are no problems with the existing button etc.
Also, I have not yet identified the specific models of the iPhones 5/6 I am working with (although I think each is the plain version, hints about how to do that with certainty would be appreciated.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Whether or not its worth it depends on how much experience you have with iPhone repairs. Remember that iPhone 6 has Touch Id home button that is married to the logic board, meaning that if you were to order a fully assembled lcd with a button and just install it as it came - you will forever lose the Touch Id function. Although if you aren't comfortable changing lcd shield and the front camera, proximity, ambient light sensor flex and installing the earpiece, it may be worth it to order the full assembly and switch the iPhone 6's home button. Personally, it wouldn't be worth a penny to me nowadays but on my first and second iPhone screen repair it might have!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
As far as how to do it - make sure you line up every screw exactly how you took it out step by step, you don't want to drive a screw too far into the wrong hole. Take your time and follow iFixit's guide. You can do it!
さんによる
Got the assy w/ot the the button. Touch ID Lives. After doing an iP4, the 5 was real easy. Working on a water damaged 6 now. If I can revive it I will replace the screen similarly, swapping in the old button.
さんによる
コメントを追加
回答を追加する
Gary Tash さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 40
