メインコンテンツにスキップ
The Samsung NP-N130-JA01US 10.1 inch Netbook PC was released April 23, 2010 and runs the Windows 7 Starter Edition operating system.
What is wrong when my battery doesn't receive charge?
I have been trying to charge my computer with its charger but it is not receiving any power to the computer. I have recently bought a battery charger to charge the battery itself but it is not working. Anything that I can to fix this problem.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
you need to check 1 or 2 things, try replacing the battery to see if that is the case, or it could be your charging port. worst case scenario it is the motherboard
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you! Well try and see if that works.
さんによる
コメントを追加
Is the computer turning on when its plugged in to the wall? If not, take the battery out of the laptop, and see if it turns on while plugged in with no battery. If it still doesn't work, then it could be your charger is bad, or it will be a problem with the charging port on the laptop, or a problem with the motherboard. A dead battery shouldn't stop the computer from turning on unless its also causing a short circuit which is not very common.
If you brought this into my shop, the first thing I would do is test a new charger. If you don't have one, see if there's a local computer repair shop nearby where they can plug in one of their chargers for you.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jorge Quintana さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 418
