Why isn't my computer retaining charge?
My computer works fine when plugged in, but when I unplug it, the battery loses charge really quickly! Is it a problem with my battery? Or is it some other issue? How can I tell?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If your computer boots when plugged in, your battery is most likely faulty, and you will need to replace it.
Try checking out our troubleshooting guide for the Toshiba Satellite A665-S5170 if you have any more questions!
このアンサーは役に立ちましたか?
It apers to be a failed or dying battery, so the fix is to replace the battery
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 10
過去 30 日: 11
今までの合計 179
