My tablet can't pwer on
I have problem about huawei tablet
it's can't power on.
I checked the connector and the battery, no problem
what is the problem?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@mohamedeln , med, Found this info. from searching through forums with similar issue as your huawei tablet t1. Hard reset. Take your sim card and memory card from the tab before the reset, battery is fully charged. Personal data from the tab, contacts, pictures, messages, apps. etc., will be deleted if it was not backed up.
Press and hold volume down key and power key for a while, your screen should turn on with option to enter recovery, follow the prompts to enter recovery mode and set the device to factory defaults. Check the link below for tutoral on reset. Good luck.
このアンサーは役に立ちましたか?
My phone doesn't have any network
My tablet says that it still needs more charging, even though it doesnt
How am I supposed to hard reset it if my screen is still black
my photos are not saved in sd card they are saved in tablet, i don't want to delete those
i try all of the ways but nothing works please help me
過去 24時間: 3
過去 7 日: 25
過去 30 日: 173
今までの合計 45,838
14 件のコメント
where to buy an extra board power ic ?
Jozhua Linda さんによる
it's can't read the puce
fatima さんによる
My Huawei t7 cannot power on. I have also press the reset button (volume up+power), but it's not responding. Can I solve it with PC?
Saleh Akram さんによる
my huawei t3 7 can power on but the screen is blank what should i do?
Samkelo Chief さんによる
It ask me for a code.
Melissa さんによる
9件以上のコメントを表示
