メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Get data ( SSD ) out from dead MBP retina 2015
A couple of days ago I dropped a cup of coffee on my MBP retina 2015 :(
after few hours the keyboard progressively lost functionality (because of the sugar) and now it's impossible to switch the laptop on. Sad to say it is just 3 months old....
Before to fix it (looks like a long process.. ), I urgently need the files and data I have on it.
I read MBP Retina 2015 mounts a PCIe M.2 SSD, so i guess I have few alternative to get the data out of it:
-get the SSD an put it in my MBP Late 2009 A1286 which mounts a Sata HD. There are adaptors for few bucks but I´m not sure about the compatibility with PCIe M.2. Ok that I won't take advantage of full speed but at least I can access my data and make the A1278 faster for free ;)
- get the SSD and put it in a external enclosure. I saw few available but I'm not sure are compatible with my SSD
Are both alternatives possible? Which way you would recommend?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Hey, did you manage to recover the data in the end with that external enclosure? I have a friend who's MB 2015 just died.
Thanks
さんによる
コメントを追加
1 件の回答
ベストアンサー
You'er in luck!
OWC has an external case you can mount the SSD into so you can gain access to the files. Here's the case: OWC Envoy Pro Portable, Bus-Powered USB 3.0 SSD Case (June 2013-Current Mac Models)
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
Thanks Dan! But actually I was half lucky :) my 2009 MBP still slow...!
How can I put thee SSD from MBP 2015 to MBP 2009 ?
Something like this can work as adapter?
https://www.startech.com/HDD/Adapters/M-...
さんによる
Sorry, not workable, Apple's blade SSD is not compatible with any M.2 frame. Sad to say you'll need to buy a 2.5" SSD for your slow MacBook Pro ;-}
さんによる
Thanks again man, but I´ll follow the LEAN process :) I mean, it´s just a matter of time.. if OWC made a workable card from Apple's M.2 (MBP 2015) to usb... i think that soon will be available an M.2 to SATA. isn´t it?
さんによる
Apple created a few different versions of blade SSD (mSATA, PCIe x2 & PCIe x4 Phy interfaces) in the case of the older retina systems (pre 2016). Each blade type has a unique mechanical interface connection (similar to M.2 but different enough).
Other than to gain access to the data on the drive which the OWC case does, I don't think people will be trying to use the SSD blade drive in an older laptop system (2.5" SATA). Think of it this way why would you buy a Maserati race car to drive to work everyday? Between the expense and the inability to push it past its crawl speed (60 mph) its more car than one would ever be able to use. This is the same case here as the Apple PCIe SSD's are just to fast for the older SATA III (6.0 Gb/s) interface.
Don't get me wrong here, reusing is the name of the game here at IFIXIT. Sadly there are limits where it works.
さんによる
I know of a few small companies they created interface boards for desktop PC's (PCI) to support the Apple SSD blades. I've also seen a 3.5" drive frame equipped to support the older mSATA blades. I've not seen anything that allows you to use either of the PCIe blades in a 2.5" or 3.5" SATA drive frame.
さんによる
コメントを追加
回答を追加する
sdiciaccio さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 23
今までの合計 10,048
