メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Why isn't my screen working?
Hello, I was recently given an iPhone 5 by my girlfriend since my old phone had died, I believe she had it for 3 years and tha battery was very worn out but it did work. Eventually the battery completely died so I opted to replace the battery myself since I have done that with phones in the past. Long story short I replaced the battery but the screen wouldn't turn on at all, so I replaced the screen with one I bought from iFixer and it turned on after some charge.
The problem now is I can only access the phone itself when it is on charge, if I take it off the phone stays on but it only shows a black screen but the backlight is on, when I plug it into the charger it comes up as it should with home screen. It will only turn on if I do a hard reset on charge.
Anyone know why it would show a black screen?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Try unplugging the battery, then the display cables, use some isopropyl alcohol and a qtip to clean the contacts, wait for it to dry, and reconnect the cables for the display, then the battery connector. I would also try a iOS reinstall through iTunes.
Let me know if this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ben さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 5
今までの合計 46
