One of the subs has noise,what to do?
I have no idea how this happened, but one of my speaker subs has noise while working.
specially when the base is a bit high. can it be fixed?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
What type of noise are you talking about?
Is it a rattle or a hum etc.?
Does it happen if you use it only with the aux cable, Bluetooth or either?
It may be that the speaker (is it coming from the left or right speaker?) itself has come loose from its mounting and is rattling when you increase the power to it.
It could also be, if it is a hum, that the appropriate input to the amplifier in the speaker i.e. Left or Right has a fault where it is introducing the hum.
In either case you will have to open the speaker and diagnose where the problem may be.
Here is a link to the Ifixit guides on how to repair your speaker. Using these will allow you to open your speaker so that the problem may be further diagnosed and hopefully repaired.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,973
