メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Why is only one "wet indikator" red
I just fixes an iPhone 5s which wasn' charging and didn't respons to DFU reset. Turns out, a new battery did the trick.
But here is whist pusseled me: The guy who sold it swore that it wasn't water damaged,
The water indikator by the ear speaker and sim tray was bright white, but the one by the battery was red. Seems impossible.
Can anyone explain?
Bjop
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
It is possible, water didn't go all the way trough the iPhone...often situation in servicing business. If everything else is ok, don't bother, carry on with usage...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
But weird though, water in the middel of the phone. I was thinking condensed water maybe.
Anyway, looks ok. Screen looks great, god response and finger print Trads perfekt. Ill run it for a couple of days to see if battery drains.
Thx
さんによる
コメントを追加
最も参考になった回答
It is most likely not water damage to the entire logic board. Probably a small amount of water from rain, or another source got into the phone. Since the water damage indicator near the battery was red, the water probably got into battery connector. This would short the pins in the connector causing rapid power cycling ultimately killing the battery. Even though replacing the battery, in this case, would fix the problem, I would recommend inspecting the logic board for any other corrosion before continuing use. Doing this will ensure you don't have any issues further down the road.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bjorn Stokke さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 58
