heat platen on heat press for sublimation
Platen on press does not heat, is this repairable?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Notto, The press is probably repairable, contact the manufacturer and see who they recommend to look at it or if they have a listing for which part may have caused your press's no heat issue, maybe just a internal fuse to replace. Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 184
5 件のコメント
How about giving us a make and model number. I'm not even sure what it is but it kind of sounds like a iron to me.
mayer さんによる
Or a laminator or heat sealer perhaps.
jayeff さんによる
@mayer @jayeff I think it is a large iron/table for transferring print/pic's onto clothing/t-shirts, Not positive, but a neighbor had one for his business.
L Pfaff さんによる
Sorry, I am not even sure what it.
Monarchy Ink さんによる
Hi, Try posting some pictures of it here. Perhaps somebody will recognize it.
iFixitでの質問に画像を追加する方法.
Also if you have an image of it you could try using Google's image search feature which tries to match the image with known images.
https://www.google.com/intl/gl/insidesea...
jayeff さんによる
