computer won't boot, hard drive error
can't seem to get my computer to boot up to windows logo, I keep getting this hard drive read error.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Ok. Since the Laptop Was Dropped. We Need To Check And See If The Hard Drive Was Knocked Loose From Its Tray. Whats The Exact Model Number Of Your Laptop. We Have Acer Aspire 5334 There Should Be Four Other Numbers. Most Likely Your Hard Drive Was Knocked Loose And The Laptop Cant Find It.
On The Bottom Of The Laptop There Is This Cover. Big And Long. Take A Screwdriver And Remove That Cover. Take A Look Inside And See If The Hard Drive Is Knocked Loose.
If It Did. Just Slide The Hard Drive Back Into The Connector.
Let me Know What Happens :)
このアンサーは役に立ちましたか?
I Hope This Fixes It. Because Other Wise The Hard Drive Might Have Been Damaged. Does The Hard Drive Make Any Noises Upon Turning On The Laptop. Clicking, Ticking etc
thank you so much, i followed exactly what you did, and everything works just fine now.
what is the error message that hard drive is giving? Did you try to reinstall the Operating System? If you did, did you receive any error messages? If so what were they?
このアンサーは役に立ちましたか?
I reinstalled operating system and everything works fine now. thank you
過去 24時間: 1
過去 7 日: 7
過去 30 日: 7
今までの合計 4,096
2 件のコメント
Did The Computer Recently Get Dropped ?
Carl Beebe さんによる
yes my sister recently dropped.
gilson teixeira さんによる
