Why Is My Screen Blank?
My laptop turns on but my screen is blank.
There may be a problem with the screen itself. Try to take out the memory cards and put them back in. If this does not work, then you may need to just replace the screen.
このアンサーは役に立ちましたか?
the blank screen if not the screen it self you must open the laptop pull out the motherboard with a hotair try to get vga chipset hot dont forget to use flux just little get it hot it will work
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 158
