Why won't my Keurig brew a full cup?
Every morning I brew a cup of coffee before I go to work. As of lately, I noticed that my cup isn't full. I end up making another batch of coffee, because the cup is partially filled.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Using the Keurig without cleaning it can get the coffee maker to not work as well. Over time the water line will need to be cleaned to allow it to run better. Using a descaling solution (white vinegar and water) and running it through the system will clean up the Keurig and it will fill the cup up all the way again. It also would help to fill the tank all the way to the top to make more coffee.
このアンサーは役に立ちましたか?
My Keurig starts making my coffee and within a second or two the flow of coffee slows down to a stream I try descaling I am out of ideas
yes me too. i have also completed the descale technique but still it only brews a smaller cup than normal. and it seems like the pump is not making enough pressure as it is only a drip or two of water at a time. maybe time for a new machine after 2 years?
Yep. I have the same problem with mine. Have descaled, clean needles and blown in line. Seems like it runs out of pressure before cup is finished, no matter what size cup I try to brew. I only make one cup a day, maybe that is the problem. However, for the machine to last about a year is too expensive. This is my second machine. I am going to look for an alternative way to make coffee. Maybe another brand. Don't know yet
Hmm, we have the "couple of drips of water" problem at work. I've inherited the Keurig machine now. I was intrigued by the "burping" solution below, but I'm betting that's not a permanent solution. My diagnostic belief is that the single impeller pump below the water reservoir is the source of the problem. I know I can access/remove/replace the pump, and I'll bet a suitable replacement pump can be purchased for less than $10. More on this as I make more progress (maybe including pictures).
Mine does this too...but it started a week after we got it...only 5 cups brewed. Does it really get dirty so quickly?
Seems silly - but turn it upside down and hit the bottom - it's called "burping" it. Has worked for me every time.
このアンサーは役に立ちましたか?
Thanks! This worked! I turned it upside down and it burped. Wow!
Thank you for the burping tip. I did all the needle cleaning with no improvement and the bang on the bottom worked. I am getting a full cup.
I can’t believe this worked but it did. Burp away!
I can’t believe it either. Burping worked. Making coffee again just like new!!!
truly look forwarding to HITTING it.......If it doesn't work, at least i will feel better. ginger westin
Some things I have found as I cruised the internet looking for a solution to this problem:
1) Most commonly, the upper puncture needle becomes clogged. This needle pierces the top "paper" in the center and pushes hot water into the K-cup. The solution is to run an unfolded paper clip up each of the three channels in the needle to clear the blockage.
2) Also referenced is a clogged lower puncture needle. This needle puts a hole in the edge of the plastic "cup" to provide a drain where brewed coffee can exit the K-cup.
3) Calcium build-up in the lines can restrict flow. Periodic descaling with vinegar is the fix for this build-up. Run several reservoirs full of plain water to purge the system of residual vinegar.
4) The exit from the water reservoir may be clogged. Taking the plate off the bottom gives access to the drain and filter. It is easily done just, need a screwdriver and a pair of pliers to take a pinch clamp off tubing.
5) It has been reported that a resounding blow or two to an upside down Keurig has started good flow.
6) Air pressure from an air pump drives the hot water out of the boiler, through the K-cup and into your coffee cup. A failing air pump can deliver a cup less full. There is a very simple way to lubricate the diaphragms in the air pump with vegetable oil. Replacing the air pump is not so simple and requires significant disassembly of your Keurig. https://youtu.be/2A_Rq1jxgwc
このアンサーは役に立ちましたか?
The problem is the k cups. Too much coffee and they plug, too fine of grind and they plug. I bought a new machine and still had the same problems. Solution punch 4 or 5 holes in the kcup bottom and brew away. We started getting this problem from time to time, some k cups are worse than others, but the holes always fix it. And if your machine is old try some of the other tips first, because sometimes it is them.
このアンサーは役に立ちましたか?
Someone gave me a Keurig when they moved out of the place I moved into is very loud and it has been giving me less than half of the amount of coffee that I asked for. I have tried each and every one of these things that did not require disassembly as I am very non Technical and afraid to take it apart and not be able to reassemble. I am a sixty-year-old very arthritic person who always wanted a Keurig but will not and cannot spend the money. I took my little four cup regular coffee out from under the sink and I will either give this away to someone who wants to play with it or just donate it. So glad I didn't pay for this thing. But my daughter a tiny little imitation one for her camper for $8 at a yard sale a few years ago and it works beautifully . Keurig is just a name
このアンサーは役に立ちましたか?
None of these solutions worked. I have shaken, burped, paperclipped, and vinegared to zero avail. My favorite bit of adding insult to injury was the answer to “simply remove the bottom tray with a screwdriver” when two of the screws require a weird hexagonal tool that normal people don’t have. Ridiculous. Anyways, I’m kind of relieved that we can go back to using our old coffee pot. It makes way better coffee anyway.
このアンサーは役に立ちましたか?
After doing all the non-disassembly tips I tried to run vinegar and water through it. The result was that now it won’t work at all.
My 2-year-old Keurig 2.0 would not fill a cup. For example, I would get maybe 1-2 ounces when I asked for 12 ounces. After thoroughly descaling and trying multiple solutions found on various sites (including “burping” as mentioned on this site), I called Keurig. After going through their troubleshooting steps, they said the next step was to send me a new water reservoir, which they did for free. I didn’t think it would help, but that actually solved the problem. It’s working perfectly now.
このアンサーは役に立ちましたか?
My Keurig is 3 years old and the same thing has happened to me. I burped the Keurig a few times and then dissolved a denture tablet in a glass of water and poured that into the reservoir and ran it through. The water pressure was instantly returned and a disgusting amount of coffee grounds came out. My Keurig is good as new!
このアンサーは役に立ちましたか?
I have a classic single serve with a 46 oz. reservoir tank. I did the paper clip, the vinegar, the burp, and still not enough water came out for a cup. I did not want to take the bottom off the unit. Finally I removed the tank and saw the three screws holding a screen filter in the bottom of the tank. I have small hands and probably could have gotten this apart, but I questioned the reassembly. I turned the tank over and saw this was a spring loaded release from the tank to the machine. Another reason not to take it apart. I pushed in the spring load and ran water through the tank, reversing the flow of water. When I held the tank up to the light I could see some of the debre had come lose. I kept this up until the majority of the screen was clear. I now get a full cup and the machine no longer sounds like Eeyore as it pumps water. Not sure I would run a denture table through the machine, but I might use it as a stand alone in the tank if this persists.
このアンサーは役に立ちましたか?
My first Keurig supreme failed after 5 months. It was replaced by Keurig. Six months in to the life of replacement it failed again. This time I’m getting the run around. Time to ditch the junky Keurig .
No need to poke and prod and bang the machine, first you'll do way better to remove the rubber pieces on the two needles, if anything is clogged it's the little tiny screen inside the machine under your water resivoir but a tooth brush, vinegar CLR can do that, best bet, find something fits over that little whole that lets the water in block the return and blow through that ##&&% till you get $@$* coming out, then run a few resivoir if vinegar, lemon juice is great and I add salt cause it's does science $@$* to water
このアンサーは役に立ちましたか?
You might have scale buildup, clogged needles, or dirty water valves if your Keurig does not brew a full cup.
You may have a software issue or an electrical component failure if your machine has been properly cleaned.
Check out this article for detailed instructions.
このアンサーは役に立ちましたか?
Same problem, 2oz when wanting 12. Took unit apart. When I take pump out of its normal upright position it pumps a full cup. When I put pump back in its snap in location, 2oz.
このアンサーは役に立ちましたか?
Pump or filter? For the others that might read this, taking the filter out is easy, it's at the bottom of a plastic column in the water tank. There is a replaceable carbon cartridge at the bottom. Taking the pump out requires some disassembly of the unit.
過去 24時間: 21
過去 7 日: 177
過去 30 日: 989
今までの合計 140,187
4 件のコメント
I also have the half cup issue. I have descaled many times with little success. Now what? Is there a component that fails that causes this problem? If so, can I replace that part myself?
Mike S さんによる
I have been going crazy with this problem! Descaled, cleaned lines, cleaned the needles. Nothing seemed to work... Until I looked into the reservoir and saw the little screen at the bottom. My dryer filter sometimes clogs and I have to scrub it with a brush. Couldn't hurt. I was getting ready to pitch the thing. So, I scrubbed it and ran a cup. That did the trick! Full cup, again.
Ruth Lucas さんによる
This was happening to me and I realized that part of the cord was tucked under the machine so it wasn’t brewing on a flat surface. Make sure the cord isn’t tucked under. The Kureg has little feet so it’s easy for them to get trapped
Devon Talovic さんによる
I used the Ruth Lucas fix and it worked well. Cleaning the screen is a little tricky. Used a brush from my rotary tool set. Did not use the tool! Scubed it up as best i could and used some blue dawn soak for a while. Now it does 6,8,12 ounces like it should. Thank you Ruth! Saved me some serious cash!
Tom Powell
thoswayp さんによる
