How do I replace the iPod Touch 2nd Gen. Dock Connector
How do I replace the old broken dock connector with a new dock connector, for iPod Touch 2nd Gen.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Well, if you look at this tear down
iPod Touch 2nd Generation Teardown
step 12 and 13 gives you a close up. I suggest you take it apart to find out more.
- feed back is important, so please update on progress.
このアンサーは役に立ちましたか?
You have to remove the logic board and then remove the dock connector by de-soldering the 30 pin connector. And also desolder the 2 side anchor points. And then reorder the new connector on. The job is very tedious. We charge around $65 in case you were shopping around for a repair place. See my profile to get in contact with me.
このアンサーは役に立ちましたか?
Hi there,
Where are you situated. Are you in the Laval or Montreal area?
Hani Choucrallah, looks like quickifixdotcom hasn't been active on here since Dec 2010. you can check his profile and see if there is an email address.
ok thanks
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 12,339
