メインコンテンツにスキップ
Power Flex Cable Replacement Issue
So i seen the power flex on this ipad was bad, could see there was a tear. So i replaced with another and of course the adhesive on it is terrible nothing wanted to stick in place. So i used a bit of super glue. Now Iam not sure if this caused an issue or not. When i first got it all connected and in place, I tested Boom Ipad comes on No problem. Seal it all up. Nothing will not power on via the power button. Connected it to the power cord, comes up. I removed the power flex again and looked at the cable it does not look "damage" But i am wondering if the super glue could have damanged the flex?
Something else i can try?
Any suggestions are helpful
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I would order another power flex cable. Its clear that the cable is damaged if it is no longer working and power on when plugged in. Very easy thing to do while replacing the screens on these.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mikebarkas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 55
