メインコンテンツにスキップ
Released 2015, identified by model number Z812.
55回答 すべてを表示
Waterlogged phone will turn on but can't see screen
My maven was dropped in water and I didn't know till now it was waterlogged for months it turns on i just can't see the screen and I have to be in the to barely see the screen.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best
Another source from here on repairing wet phones
Electronics Water Damage
Hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
shawnprinze さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 150
