Why won’t my GPS turn on?
Even after charging my device, when I press the power button, the GPS is not turning on. I have even tried replacing the battery, and it is still not turning on.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
There could be multiple reasons why your device is not turning on. Consider checking to see if your charger is working properly by testing it on a separate device. If it is not a defective charger, then there may be more serious issues such as a faulty motherboard or display screen. For more information regarding a defective motherboard or screen damage, please refer to the Garmin Nuvi 2589LMT troubleshooting page here.
このアンサーは役に立ちましたか?
The Nuvi 65 powering system is the most frustrating, mind bogglingly perverted and useless device I have ever owned. I love the Garmin free maps an updates but the power nightmare should simply not be an issue. I'd like a refund even out of guarantee. Shame on you Garmin. How the !&&* can you d design and develop such junk.
I find the device totally unreliable and therefor mostly unusable . Everything other than this operates fine and in correct manner. There most certainly is a design flaw in the powering/charging/data setup. Who the !&&* needs this hastle. Back to older maps and my old flipping tomtom.
I had the same exact problem and was ready to pull my hair out and bring it back to BestBuy to get it fixed.After it was not charging in our car, I connected it to a desktop. It still would not charge so I plugged it into my portable charger and my Garmin started up just fine.
It is a faulty charger that can be easily replaced but causes
much frustration when you are in traffic depending on it.
I had a similar problem...
Searching through the internet, I found that holding down the power button reset my device.
So with a little search, you can find someone who already had the problem & was kind enough to post it to the interwebs.
Thanks, my Garmin 58 LM is back up and running for my delivery job!
I also have the 55LM unit as a backup
Both are running flawlessly for over the 3 years that I owned them used from Craig's list.
I also own 2 older 1300 series with lifetime map updates. Still works to this day, used from Craig's list as well
Also had a Magellan GPS, but prefer the interface of the Garmin
このアンサーは役に立ちましたか?
My Garmin Nuvi we'll just shut down and refuse to turn back on. Sometimes it will come back on if I hold the power button down but most of the time it will go for days or even a couple of weeks without me being able to turn it back on. It works great when it works though!
my nuvi 2589 would not turn on . then tried next day and it worked but how can you rely on it to make a jouney, can’t wait till next day to see if it will work
このアンサーは役に立ちましたか?
We all see that there is a problem so, what’s the solution? My GARMIN is my baby, I always relied upon its service to get me from point A to point B and back to point A again, home. Can they be fix or are they considered throw-aways. I purchase mine from Radio Shack years ago.
m/n:nuvi 50LM 336067097
Tawanah Orange
4/22/2019
このアンサーは役に立ちましたか?
this is the second garmin that wont turn on anymore,,i consider these $@$* and should have stuck with the tom tom i had for years, pilled it out of the desk after sitting for years and it still works fine, the garmin is pretty much a one year use disposable piece of crap
このアンサーは役に立ちましたか?
Their are so may reasons, why Garmin GPS won’t turn on. The main reason is the battery problem.
Try to update your device or reset the device to fix this issue.
このアンサーは役に立ちましたか?
Some popular Gps devices like- Magellan devices like magellan maestro 3200,magellan roadmate 1440,magellan maestro 4040, magellan roadmate 5235t-lm,magellan roadmate 1700,magellan roadmate 1470, and other old and newer models. We’ll help you to get easy maps, software / Firmware updates.
Are you planning a trip or going out and wondering if you could have the latest maps to make your trip or your work. Well, you’re a step away from the latest map updates. Latest map updates make sure that you always reach your destination on time with full-proof accuracy.Magellan roadmate Updates
このアンサーは役に立ちましたか?
過去 24時間: 11
過去 7 日: 53
過去 30 日: 188
今までの合計 62,753
7 件のコメント
even with battery fully charged, sometimes my garmin 2589lmt will not come on. this happened on sunday so i just left it plugged in. on returning from this 60 mile trip it came on as i pulled into the driveway. this also happens in my co. truck. it's a 2016 nissan frontier. help!!!!
lamar flanders さんによる
I am so not impressed with the Garmin Nuvi that I purchased 2 months ago. It is always turning off and unable to get is to work when driving. This is the second time in 2 months since I purchased it that it is not working. At this point I am ready to try a more reliable GPS. This is so frustrating to me at this point. My old GPS did not have 1/90th of the problems I an experiencing with this piece of garbage. Very unhappy with this device.
Mikemarr さんによる
I am so not impressed with the Garmin Nuvi that I purchased 2 months ago. It is always turning off and unable to get is to work when driving. This is the second time in 2 months since I purchased it that it is not working. At this point I am ready to try a more reliable GPS. This is so frustrating to me at this point. My old GPS did not have 1/90th of the problems I an experiencing with this piece of garbage. Very unhappy with this device. I so agree with you. Very unreliable and difficult to get help to fix the stupid product that only works occasionallyl
Mikemarr さんによる
My portable GPS garmin won't come on. When on charge only even if the battery is in it the same thing no power. What might be it's issue?
Natalia Tarsha Attidore さんによる
Well this is the last time I buy Garmin, I have had 2 , always the problem, after a few years it won't turn on. Someone has had a Tom Tom and never a problem, guess what my next gps is gone to be. Don't rely on this product as it is written . not true. Great when it works , unfortunately its not for long. Very disapointed.
DMadd さんによる
2件以上のコメントを表示
