How do I put my phone into safe mode
== I am trying to put my phone onto safe mode to remove apps i dont need and I have no clue how to do so ==
Below is just a general method of entering safe mode & may not be specifically for your huawei model but the method doesn't usually differ too much so its worth a try. Hopefully it works for you!
When switching on the phone, press and hold the volume down button and the phone will enter safe mode.
When the phone is switched on, if you press and hold the power button and select Power off in the displayed menu, the system will display a Reboot to safe mode dialog box. Touch OK to restart your phone and enter safe mode.
After entering safe mode, a prompt will be displayed in the lower left corner of the screen.
Some phone models do not support safe mode.
このアンサーは役に立ちましたか?
Did someone hack into my phone to put safe mode in
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 221
