メインコンテンツにスキップ
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117回答 すべてを表示
Why can't I boot from any source?
Hi! I have an iBook G3 500 MHZ and I have recently replaced the DC-in board and put in a newer hard drive from one of my dead iBooks and a slot-loading combo drive. My computer now won't boot from anything. I have tried my internal hard drive, which has OSX 10.3 on it, firewire target disk mode from 2 iBook G4's, and Mac OSX 10.4 Tiger installation DVD boot. When the iBook starts up the screen flashes, becomes black, and lights up again with a blinking ? and Finder icon. I start up again while holding the option key and the blue screen with my hard drive, install DVD, etc. comes up. I wait for the watch to go away and click the install DVD, and then the right arrow. The screen then flashes blue and starts finding the disks again. It doesn't boot. What is wrong?
UPDATE: I just installed Tiger on the iBook using Firewire Target Disk Mode and confirmed that the drive is just fine.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
I have confirmed that the hard drive works just fine because l booted off of another iBook. I just finished testing the combo drive by sticking it in an intel iMac and it works like a charm too. Does my book not like osx?
さんによる
コメントを追加
1 件の回答
ベストアンサー
You have changed to many things without confirming they worked before going on. You need to go back to the first change and make sure it works and proceed with one change at a time. There is no way for us to know which alteration has caused the problem.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
good answer +
さんによる
コメントを追加
回答を追加する
Jack Byrnes さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 897
