メインコンテンツにスキップ
The Samsung 5 Megapixel camcorder was released in 2011. It can be submerged in water up to a maximum of 3 meters and dropped from a maximum of 2 meters. It also records video in 1080P.
Why my camcorder won't turn on?
No matter what I do I cannot get the camcorder to turn on. I have charge it for several hours and even check the led on the side is lit when plugged in. The camcorder only has a little over a year and I have used it only a few time, so I don't think is the battery. ANY SUGGESTIONS ???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Since you've tried charging it, you might have to change the screen display according to the trouble page for the device ( Samsung HMX-W200 Troubleshooting ).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello,
Since you stated you tried to charge your camcorder without any luck, you may have a faulty USB charging port. But do not worry as you can follow the guide here (Samsung HMX-W200 Troubleshooting).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Antonio Abades Lescano さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,419
