Hi,
Thinking about your question again, I do not think that the Smart power setting will be the problem. As you have not finished 'booting', by reaching the home screen, it seems more likely that you have a firmware glitch.
As there are no firmware updates available from the Philips website to see if reloading it would solve your problem, my only suggestion now is to try and reset the device, by removing all the power from the device, (I know you said that you have already tried pressing the reset button) .
Disconnect the charger, remove the battery and then press and hold the Power button for 15 seconds to remove any residual power from the device. Reinstall the battery, reconnect the charger and then see if it starts normally. If it does you may find that you have lost all your pictures as I do not know if the memory is of the volatile or non-volatile kind. I'm thinking non-volatile because they wouldn't want you to lose it if the battery went flat. Just so you are aware of the possibility.
Here is an image, taken from the User guide on how to remove the battery. Click on the image to enlarge it for better viewing.
4 件のコメント
I've tried using the reset button, but the Photoframe still shuts itself down during the bootup process.
mudfacehenrylee さんによる
Hi, Does this happen if you have the charger connected or only when running on the battery? Is the Smart Power setting enabled or disabled? have you set the correct date and time?
jayeff さんによる
@jayeff It appears to happen with both situations. The date and time haven't been set because I don't need them; I'm not sure if the Smart Power setting has been enabled or not because the Photoframe was working at the same times for the past few days.
In addition, I can't check if Smart Power is on or not because the Photoframe switches itself off before the home page loads.
