メインコンテンツにスキップ
The Jeep Cherokee (XJ) is a compact SUV that was manufactured and marketed by Jeep from 1997 to 2001. Sharing the name of the original full-size SJ model, but without a traditional body-on-frame chassis, the XJ instead featured a light-weight unibody design.
40回答 すべてを表示
My signal lights don't work all the time.
My signal lights do not work all the time. I have checked every fuse in the fuse box and they are good. I checked all the fuses up under the hood and they are good. I noticed that at night the signals will work sometimes but as soon as I turn the headlights on they stop working.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Hi,
This link may be of interest to you as it explains the cause of the problem that you are having. Read through all the posts.
http://www.cherokeeforum.com/f2/turn-sig...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
@dohomer632 , Flasher being 15 years old would be a cheap part to change to rule it out and can be intermittent. If all fuses/relays/flasher/bulbs seem OK, it is probably the multi function switch, the contacts inside the switch overtime become worn, dirty and some times burnt causing intermittent signal. You could try disassembling the switch and cleaning contacts with contact cleaner and tooth brush, fine emery sand paper, or if just light corrosion a pencil eraser will work or just replace it with a new one. Use the links below for instruction on changing flasher and if need be how to change the multi function switch. Good luck.
https://www.youtube.com/watch?v=py9JlxaD...
https://www.youtube.com/watch?v=HEZDdqyO...
http://www.jeepforum.com/forum/f11/write...
https://www.youtube.com/watch?v=vE-ygM16...
https://www.youtube.com/watch?v=7-TtnITW...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Keith clark さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 78
