Frame slightly bent, CD's will not eject unless pressure is applied
The frame around the optical drive is slightly bent, not in a way you would normally notice. You have to look level across the keyboard to see a slight depression to the right of the trackpad above the CD drive (cd drive slot ever so slightly bent as well).
CD/DVDs will not eject unless pressure is applied to bend/straiten the frame slightly. With just with hand pressure around the optical drive area while someone else pushes the eject button.
Is it possible to bend, or manipulate the metal back to a suitable form to allow the CD drive to function again? (without making it worse, not fit back together or just have the metal go back into its current state once reassembled). If so, best way to do it?
Just looking for a way to make it functional again, when so close to working correctly on its own.
この質問は役に立ちましたか?
1件のコメント
the display frame is bent in the middle too, with a gap at both ends showing when the display is closed, .........another question i guess.......
Brian さんによる
