メインコンテンツにスキップ
Samsung Galaxy S4はモデル番号i9505、13メガピクセルの背面カメラ、5インチ 1080ピクセルのディスプレイを備えています。
526回答 すべてを表示
Galaxy s4 camera fail
When I use the camera app it shows just a black screen and it says camera failed. Also I tried using a third party camera app and the front camera worked but the rear had green lines running across the screen. I went online and tried everything software wise to get it back to normal. I wiped the cache Portion and did a factory reset but still the same thing happened. Then I bought a new rear camera and still nothing. When I opened the third party camera the screen was black for the rear but worked in the front. Any other ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Could it be possible that the phone was in contact with water? Did you try cleaning the connector before reassembling the new camera part? Have you tried flashing another firmware?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It may be possible I bought it from someone I know and I doubt it had had water damage. I don't think I did clean the connectors how should I try? And how do I flash another firmware
さんによる
コメントを追加
回答を追加する
Gabriel Huerta さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 107
