メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
904回答 すべてを表示
One of the click wheel buttons not working
I'm trying to fix an iPod Classic with a broken click wheel button (play/pause). All of the other buttons are working. From previous questions I've seen people suggesting to replace the click wheel, but I'm afraid that won't solve the problem (since clicks are registered by the buttons underneath, black dots on this picture.
Is there anyone with the same problem that fixed this by replacing the click wheel itself? Or any other suggestions?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
@lpirar one thing you can do is measure the switch itself. Attach the leads from your multimeter to the bottom two contacts, you should see that the switch does have some resistance, and total continuity when depressed. If the switch itself checks out okay, you may have to replace the clickwheel or at worst the logic board. Make sure that the clickwheel can make contact with the switch. Sometimes the little rubber bumpers on top of the microswitches come off and preventing proper contact.
Open
Depressed switch
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for the information, I'll give this a try. Let's hope it's the clickwheel itself :)
さんによる
コメントを追加
Hello, i just resently replaced my click wheel on my ipod video and its wont scroll or click on anything. when i swith the hold swith the backlight will come on and the only inputs that the ipod will recieve is a soft reset when i hold down start and select. But thats it and nothing else.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lucas Pirard さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 761
