Why can't I access my keyboard while trying to text a message
Why can't I access my keyboard while trying to send a text message? The keyboard will not open
Hi..I just went to my apps and checked the gboard app which is the keyboard i use and it needed an update and walla ..i go back to messenger and my keyboard is again working. Hope this helps! so much for automatically downloads the updates eh?
このアンサーは役に立ちましたか?
Thank you! This also worked for me
you rock!!!! thank you so much!!!!!
me, too! Thanks a bunch!
go to settings > application manager > find your keyboard app to the download section if its is downloaded thru play store but if your keyboard is system app check it to running section and press your keyboard app then you will be directed to keyboard setting and the press the clear data button on your screen then reboot your phone if necessary..
thanks.
このアンサーは役に立ちましたか?
all section my mistake ^_^
When I use voice text when I am messaging a person on a date site, my phone all of a sudden delete it, does anyone know what’s going on
Had same problem. Go to Settings. Then Apps & notifications. Tap App info which will take you to your list. Scroll down to Gboard. . Enable! Works
このアンサーは役に立ちましたか?
This one was most helpful and to the point. I had to put gboard in search because when I scrolled down if wasnt there, but it worked!
Thank you, so much!!!
Kudos & appreciation!
Same problem with an older phone. Simple solution, go to app store. Voice command Samsung keyboard (mine a Samsung). There are dozens of free keyboard apps. Pick one, it will guide you thru the install. Took about 2 minutes. It works! Hope this helps.
このアンサーは役に立ちましたか?
I have a screen that covers where the keyboard should show---the actual keyboard appears as a tiny square in the top right corner of the screen
このアンサーは役に立ちましたか?
How do I close my texts when I’m done with the key?
このアンサーは役に立ちましたか?
How do I accomplish this?
Thank you?
H
What does it mean when I try to text message and send it comes up just showing the numbers between 1 0
このアンサーは役に立ちましたか?
過去 24時間: 7
過去 7 日: 51
過去 30 日: 298
今までの合計 50,868
20 件のコメント
cannot type on my Messenger on my phone why
Kalima ALI さんによる
Keyboard does not appear on my phone to send text messages
lee.berteit37 さんによる
I am not able to type
Rosa Gray さんによる
I had this problem too and it kept putting hyphened or other language letters too. Re installed Google keyboard and deleted all languages except English and seems to be working like it's supposed to!!
Lisa Muir さんによる
@Kalima ALI
Try deleting all languages except your own and re install Google Keyboard. I just figured this out myself and it's working as it should!!
Lisa Muir さんによる
15件以上のコメントを表示
