Clicking sound coming from the wheels when they spin?
While riding my board, or just spinning the wheels, I can hear a clicking sound coming from from my rear wheels.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It is most likely the pulley bearings or the skateboard bearings that are making the sound. First, try cleaning the bearings. If the sounds continues, you'll need to replace the bearings. Refer to the troubleshooting page for more help, or check out one of the repair guides.
この回答は役に立ちましたか?
Sorry I did not see that this was a student question.
It can be the bearings, the cores or the spacers, See the discussion here:
この回答は役に立ちましたか?
過去 24時間: 4
過去 7 日: 30
過去 30 日: 122
今までの合計 6,650
Take off your belts. Grab a screwdriver. Remove pebbles and debris, gently, from the black plastic ridges. I had this problem, and found that pebbles were hitting the plastic cover on rotation.
Joe Fortier さんによる
