Why is phone not holding charge
Screen has popped open in a section left side of phone tried putting pressure no difference
AH!! dont push! you will need to get a tool kit(pentalobe) , remove the two bottom screws and reinsert the tabs on the inside of the screen into the frame! push any harder and you will damage the LCD.
if your battery isnt charging i would check the charge port OR battery. maybe even the cord you are using
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 61
