*#06# won't show imei
when i type *#06# won't show imei
but when i go to settings/about imei is there
i have no service
Check your modem firmware. Go to settings,general and about and check if there are numbers there,if no numbers it means firmware is corrupted. First restore your phone and if still problem not solved then you go the hardware way. You'd have to change your base band chip which is a bit difficult.
このアンサーは役に立ちましたか?
it's not firmware issue it's hardware
I think the baseband needs to be reballed, this is a common issue. During update or restore do you get error -1? If you do then it definently needs to be reballed.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 3,853
i need a answer for this question too . i have more then 5 iphones same issue
r.o0y さんによる
do you do microsoldering
Adrian Zymeri さんによる
Pls help me with my iPhone 6 plus Didn't show IMEI number
Oluwaloniglory さんによる
