メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
715回答 すべてを表示
My port to the HDMI is broken in the Xbox
My question is I broke the inside HDMI port for TV output from my Xbox one. Is there any Alternative way to play my xbox some how? If not where can I get the parts to fix it and is there a guide on that?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
1件のコメント
Can you not just take the HDMI in pass through port and desolated it and move it to the HDMI out port to make it work for now and fix hdmi in if you even care about it.
さんによる
コメントを追加
9件の回答
最も参考になった回答
If you search "Xbox One HDMI Port" on eBay, they have the part on there. There are also lots of videos on YouTube showing how to replace it.
I would warn you though, if you don't have experience in soldering, you could damage the main board trying to remove the old port. If you're not comfortable with the repair, it would be worth having an experienced tech do the soldering work for you.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
David is right. I fix lots of them where someone has tried to fix it but didn't know how. It ends up costing them a lot more because they tear the circuits traces off the motherboard.
I get that people like to fix stuff themselves but just be realistic with your abilities and tools.
さんによる
コメントを追加
If you get a hdmi to USB adapter can you not plug the hdmi cable in one of the Xbox’s usb slots?
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
Yes I would like to know this. I am trying to find a solution to my sons hdmi issue on his 1 yr old xbox minecraft edition
さんによる
Yes i would like to know trying to see if i should buy one
さんによる
Anyone ever try it?
さんによる
I bought one offline and it isn’t working for me at all
さんによる
Any luck with this yet?
さんによる
4件以上のコメントを表示
コメントを追加
you should be able to get the parts here on I fix it but maybe radioshack or some other eletronuics bussiness
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
ifixit does not sell those parts, nor does RadioShack or any other brick and mortar store that I know of. It's an online only part.
さんによる
コメントを追加
hdmi port replacement on xbox requires micro soldering and desoldering technique otherwise you will end up breaking the pads on logic board we have done many hdmi port replacement in our workshop for us it is easy if you live in new eland you can send it to us
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What is your workshop?
さんによる
コメントを追加
Get it from eBay like everyone said, or if you have a pc with windows ten, you can stream it directly to the pc and plug the controller to the pc or turn it on and play without it being plugged up to the TV
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Please elaborate on this .... I have the same problem
さんによる
コメントを追加
Yes I have the same broken hdmi slot
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Can you not just take the HDMI IN pass through port and desolder it and move it to the HDMI OUT port to make it work for now and fix hdmi in if you even care about it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i really wanted to get the Fortnite battle pass so iam sad
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
connect a controller to your phone and do remote play through the xbox app
このアンサーは役に立ちましたか?
スコア -1
コメントを追加
回答を追加する
Ryan さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 33
過去 30 日: 222
今までの合計 68,772
