Display Repair 6S Diagonal Lines
Almost everytime i do repair a LCD for iphone 6s with OCA and laminating machine,
i do get these diagonal lines in the Backlight.
Still didn't find any solution or reason.
Any suggestions?
Seems like you are putting this LCD on the Autoclave machine for a very long time to remove small bubbles. At least that happens to us when when put for a very long time. A simple backlight replacement will do.
このアンサーは役に立ちましたか?
Hi,
I am getting the same issue with iPhone 7 screens, they are only in the autoclave for 10 minutes? Set at 45 degrees and 0.6 pressure. Tried to use limited liquid to clean too…
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 597
