メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2688回答 すべてを表示
Microphone sounds muffled after port replacement
Replaced the lightening port (phone stopped charging). The microphone sounds muffled to callers. In case it was faulty, I replaced it with 3 different parts with all the same results.
Checked and removed excess adhesive on the microphone, checked placement and made sure the hole is clear, phone charges great with each new part except the microphone is still muffled.
What is going on???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Are you using the rubber mic housing? Did you make sure it doesn't have any dust in its holes/cavities?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Probably microphone isn't in correct position, it have to be putted correctly in to hole, if it will be not, youre callers may have problems while calling You like their own voices in their earspeakers.
There's low chance to have damaged 3 mics (everything is possible, you don't know who and how disconected those flex from phone - maybe some1 used to high temperature and melt the speaker), but You can also try use a IPA and toothbrush and gently clear the port on motherboard.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I am having this problem now, jliscum31, did you find an answer or solution?
I have replaced the charge port twice. I made sure to not cover the microphone hole with adhesive. I tried to ensure the microphone was lined up in placement. The callers complain he sounds muffled and his voice cuts in and out.
Any thoughts!?
Thank you!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jliscum31 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 1,436
